-   -   Xr drive torque (https://www.offshoreonly.com/forums/general-boating-discussion/323308-xr-drive-torque.html)
Hopper 02-20-2015 07:16 PM
thanks for the replies..... they are the new XR's I knew they come on the 600 SCI but Merc does not seem to post torque #'s on the engines..... I just wanted to see if Merc actually had a torque rating on them... running twins just did dyno's 525SC reliable 575HP 600 Torq... I know I am safe as long as I don't pound on them hard... Heavy Old Formula boat anchor compared to the newer boats.........
chris21hope 02-20-2015 09:11 PM
Originally Posted by onesickpantera (Post 4267838)
If you do a search you will see they can handle 300-800 lbs of torque. :cool-smiley-011:
On the serious side, it all depends on the variables. Weight of boat, where you boat, single or twins, how you drive, etc. A buddy had a 700+hp engine in front of a stock Bravo and it lasted for 4 or 5 years. When he grenaded that one, he put a Bravo X behind it and never had any problems. But he was easy on the holeshots and didn't get into big water often. He went with the X over the XR based on some advice from a very knowledgeable member.
I've heard a lot of guys say that, if you're running too much power through a drive, it hardly matters how you work with the sticks because they aren't going to last either way. But I've also heard a lot of people say what you're saying here about hole shots and big water. So what's to believe? Hard to tell.
Apexwarrior 02-21-2015 06:43 AM
After running 525's with Whipples for several years now (and an XR rebuild) in a Fastech, I will tell you to believe it all. Yes, shock in big water will kill them, as will hole shots. I used to think that if I worked the sticks carefully, I could get them to last. You can't. Rough water blew my first set, but when we opened them up you could see the pitting on all the gears from the extra torque. They were going to blow in any scenario.
Bottom line is if you make more power than they can handle, they will eventually go. Even with stock power over 500hp, I would be worried in a heavy boat.
Either you rebuild every 2-3 years or bite the bullet and upgrade..
Keith Atlanta 02-21-2015 08:59 AM
The case looks different but structurally & mechanically they are the same inside.
