Rub rail paint
Old 03-02-2015 | 06:49 PM
Default Rub rail paint
Need some help on painting my rub rail. Which holds the paint and wear better , aluminum or vynil ? Shoud an additive be used for the vynil? Need this to last ...
guilderoy is offline
Old 03-02-2015 | 10:12 PM
glassdave's Avatar
Neno the mind boggler
neither, you should not paint the rubrail because . . . . well . . . . its there for rubbin
rub rail should not be painted for any reason. Not only does it serve a very specific purpose (see above) there isn't much that will stick or hold up in any reasonable way.
08 OPA High Points Champion
glassdave is offline
Old 03-03-2015 | 03:09 AM
I am not saying one way or the other about painting rubrails. But if you are painting anything aluminum. Scuff it first with a scotchbrite disc than alodine it, prime and paint. But aluminum anything on a boat??? Corrosion is a B*****. But if you are looking for colored rubrails I was thinking about that and found Barbour Plastics. They had some different colored rubrails.
fordf350 is offline
Old 03-03-2015 | 06:03 PM
How about powder coated aluminum that's what I'm doing to mine.
jeff s is offline
Old 03-03-2015 | 09:51 PM
Scott B's Avatar
Even powdercoatimg doesn't hold up in salt..
Scott B is offline
Old 03-03-2015 | 10:23 PM
I painted my aluminum rub rail with a 5 dollar can (black) of spay paint from local hardware store. It looks very good. It's a class 6 OPA raceboat-so its on/off trailer alot. When the rub rail rubs aginst a piling and scrapes off the paint, I tape it off and spray that section again. If you want to see pics-go on www.OPARACING.org and look under class 6 for 606 Lock'd Up, from 2 years ago. I havent raced it the past two years-since Sandy flooded my house. Spraying is a cheap way to make it look good-not perfect but pretty good. I'm computer illiterate-if someone can drag over a picture-that would be great. Thanks.
Fast Shafts is offline
Old 03-03-2015 | 10:45 PM
BUP
OPA under race teams has 602 and 607 listed no 606. FYI
I believe Cigarette paints and or uses some colored rub rails on their current boats - not all but some. Possible Outerlimits as well
BUP is offline
Old 03-03-2015 | 10:54 PM
BUP- I didnt race the past two years-so I'm not listed as a current team. If you go to the gallery section, look under 2012, Bull on the Beach Grand Prix-there are several pics.
