Difference between prop speed and rpm? >
Old 03-21-2015 | 03:37 PM
Mbam's Avatar
Offshoreonly Advertiser
Originally Posted by polsprung
It seems like 'prop slip' is implied through a formula/ratio which is not what I'm after.
I need a sensor that will determine whether prop is in mid-air or underwater. I'm looking for a measure of prop slip over a duration of multiple times a second (e.g. 200hz).
Is there a sensor to measure propeller resistance?
Sounds like what you need is a strain gauge to measure the loading on the drive. Reach out to Mike Clesceri (MDC DriveGuardian) he can help you.
Mbam is offline
Old 03-22-2015 | 06:48 AM
Originally Posted by I'CE
hate to ask, but what for and why. if the wheel is mid-air/out of the water prop. slip is 100%. are you trying to measure blade load as it comes into aeration and re-enters and becomes loaded
An auto-throttle system that will plug-in to existing throttle linkages.
So to apply the concept: actuator, cable, 3DOF accelerometer and ECU
ECU logic:
1. Program RPM (6000rpm)
2. RPM Sensor (compares current rpm to 6000rpm)
3. Are we above set rpm? (If yes, release throttle cable/If no pull throttle cable)
The above method that would only work for hull exit/rpm redline, but it's missing the re-entry portion. That's because rpm is a secondary data point. The primary data I need is what you just mentioned.
Quora: What components are needed to create a marine auto-throttle system (throttles to zero when hull launches off wave)?
polsprung is offline
Old 03-22-2015 | 06:55 AM
Very cool! Never heard about that product before. I'm looking for a similar system for twin outboards though. Heard of any?
Source:
http://www.offshoreonly.com/forums/g...ear-later.html
http://www.boatingmag.com/gear/drive...imiting-clutch
http://www.marinedesigncorp.com/our-products.html
Old 03-22-2015 | 06:48 PM
Re: strain gauges, these guys were at PRI
http://tecatperformance.com/
But it might be easier just watching RPM and controlling electronic throttles . Logic would be something like:
1. If RPM suddenly spikes upward, reduce throttle to maintain the RPM that occurred just before the spike
2. When RPM suddenly spikes downward increase throttle to maintain the RPM that occurred just before the spike
3. Throttle movements by the throttle man always override computer
4. Computer control is over ridden if the boat isn't flying level
This logic isn't tied to a specific rev limit and would be applicable to rough conditions that prevent top speed/RPM. Not bouncing off the limiter either. I would think that any ECU is sampling RPM at the rate you need.
There are aftermarket traction control systems that do something similar but they use ignition retard instead of throttle movement.
http://www.moretraction.com/Products_Drag_EFI.htm
Ignition retard might react faster than the actuator in an electronic throttle, but for long "flights" throttle control is definitely preferable.
Good luck with your project!
tomcat is offline
