Mercury Sportmaster Gearcase for 300 X
The application is our 28 Skater....The new Mercury 400R specs sound as though the Sportmaster Gearcase may NOT have been revised except for the low water pickup. As we know, the 300X and XS gearcase is subject to failure, but adding the understood 100 horsepower without additional gearcase revisions does not seem logical.
The low water pickups described within the 400R specs are definitely of interest, though perhaps someone is providing that service...Any information would be appreciated. |
The gear case on the 400r is not the same as the 300x or xs. It is beefier and larger.
Forgot to mention probably a little slower also.
Double Rigged, Thanks !
I see you have 300 X's on your 28 Skater. Are you considering the 400 R ? |
Are you selling the 300x motors if you swap to 400's
Originally Posted by kvogt
(Post 4294954)
The two 300 X's are spotless w/something like 16 hours total run time. They have not been modified, hurt or damaged in any way, and they have been winterized and kept in a climate controlled building, mounted on the Skater. |
Originally Posted by CcanDo
(Post 4294818)
I see you have 300 X's on your 28 Skater. Are you considering the 400 R ? Thanks |
Two of those 400's would be a LOT of weight on the back of a 28 Skater. It might run fairly well on glass, but I would think it would be way too stern heavy to fly level in the rough!
The new 400 sportmaster is based off the larger 5.44 gear case that was introduced with the 350 verado when it originally came out
| All times are GMT -5. The time now is 11:06 AM. |
