525EFI Whipple PCM Upgrade???
You have a few choices. The one from TPIS that BUP mentioned above, CP Performance has one as well as AZ Speed.
Eddie
Anyone done this 525EFI Stage 1 Performance Upgrade?
Looking for performance changes and opinions from some that have done this. Mid to larger twin engine boats. Hear it will wake them up in the mid range, looking for some real world, I spent the coin opinions.
Thanks.
Thanks.
Thank You! Was hoping you would pick up on this.
I am doing the top ends, Isky springs, 10 degree retainers, Crower stainless rockers, Cometic gaskets, your recipe to a "T". One question here if you would, Roller lifters? What would / do you use as replacements? Are the stockers ready at 300 hours?
For what it's worth, I do believe many on here appreciate your comments and knowledge.
I do. Thank You.
I do. Thank You.
I do. Thank You.
I've yet to run into a 525 that has needed lifters at 300 hours, unless the engine had serious issues. Honestly, if I were going to replace them, I would go right back with the GM lifters that came in it. You can buy just the lifters and reuse your original dog bones and spider, thus saving some money. That is an excellent lifter and is a perfect fit for that engine. There should be no reason to replace them at this point. You will be looking at a complete in the 550 hour area, so I would wait until then if they all look good now.
Eddie
Things are going well thanks. If you do decide to go the Whipple route I would highly recommend Eddie. He did the top end on my 525 and was very reasonably priced and great to deal with. Good thing I took it to him when I did because it was just about to grenade.
Tell Sam that Lorrie and I said Hi.
you can do quite a bit to them, just remember the weak spot is the stock cool fuel, so once you start giving it m ore air you will have increase the fuel and that system cant handle too much... it go boom very quickly... when it comes time i can give you some good info and you can get up to about 650 hp.
