-   -   Thoughts on this upgrade for a 525 EFI? (https://www.offshoreonly.com/forums/general-boating-discussion/327889-thoughts-upgrade-525-efi.html)
Pwraddr 06-29-2015 10:16 AM
http://www.cpperformance.com/p-26619...y-525-efi.aspx
Who does the programming?
Think it really yields that power?
F-2 Speedy 06-29-2015 10:40 AM
Looks like you get a new ecm with the programming done, exchange on the throttle body to, bare heads ? I don't see any valves, springs, retainers in this package. Personally I would put a custom grind cam in them also. The 500 & 525 intake plenums will stop flowing air at around 5500 so it doesn't matter how much CFM the TB flows it wont make any more power, jmo
Sydwayz 06-29-2015 10:43 AM
Keith, shoot a message to REMEDY here on OSO. He's got a great plan that works on the 525s. He's seen nice upgrades on his 33 and a few other boats he's done it too.
offshorexcursion 06-29-2015 10:47 AM
Is the few mph worth increased drive issues????
Will only a few mph even satify you or leave you wanting more???
You do not need a custom cam grind there are several well known engine builders that offer a "package" similar to what's listed that will work great for you.
thirdchildhood 06-29-2015 10:59 AM
I'd spend a little more and add over 250 hp (and lots of broken bravos!) Either way requires 91 octane.. https://whipplesuperchargers.com/ind...&product_id=56
Dave M 06-29-2015 04:45 PM
Am I missing something or do they not quote specific numbers other than "increased"? How much HP does this kit produce?
mptrimshop 06-30-2015 11:10 AM
It says as much as 75-80 hp increase. Now my understanding is that most 525's make 550-560hp.... So is that really 45-55hp increase? Is the HP measured at the prop? Isn't that how merc rates them? 7k for 45-55 hp? How much MPH can one exspect to gain from 55hp per side?
BenPerfected 06-30-2015 01:26 PM
...about +2 MPH
thirdchildhood 06-30-2015 01:40 PM
$7,000 per engine to net 2 mph and the need for 91 octane is nuts! (JMO) One of the best things about the 525 is that it likes cheap 87 octane.
VoodooRob 06-30-2015 01:49 PM
I have been weighing options and talked to Eddie Young about this kit versus Whipple. The payoff for doing this particular N/A kit, and having to run 91 as 3rd pointed out, just isn't worth it IMO. I have come to the conclusion to swing for the fence (Whipple and run 91) or leave it alone, maintain to the highest standard and enjoy availability of 87.
