Hull design, anyone have any input >
Old 07-07-2015 | 03:52 PM
Thumbs up Hull design, anyone have any input
Long story short I built a I/O pontoon a few yrs back(http://www.offshoreonly.com/forums/r...oon-build.html) thought I would be happy with a 140hp and 27mph, but like anything I cant leave well enought alone and have been aquiring parts to back it better.
I should have "enough" horsepower now. Just got the LS1 off the dyno and made a little over 400hp and picked up a bravo drive to handle the HP.
Now onto center toon design. Looking for something that will plane better, after looking at all the other manufactures I came up with this.
I'm wondering if I should change the back "current" portion to have a flat bottom or leave it and it might act like a step, like the preformance v-hulls have. Thoughts?
This is what the current boat has, the issue I have is the back of the boat planes quicker then the fron thus driving the front of the boat down.
Thoughts????
Wondering if I shouldnt lower the 12" Pad to closer to the bottom of the outer toons. Less drag that way??
turbom700 is offline
Old 07-07-2015 | 04:04 PM
If you don't get an acceptable reply here, try posting your question at :
http://www.boatdesign.net/forums/multihulls/
Please keep this thread updated as I'm very interested in your design and to see this get built.
noli is offline
Old 07-07-2015 | 04:36 PM
Its hard to judge your engine box height vs the pontoon toon inner strake height. I would think that a 12" pad and two pontoons would ride terrible. Have you thought about extending your current engine box design to the front to get rid of the stern lift? also adding lift strakes on that center hull that are at the same height as the pontoon inner strakes would probably work well. you can stop the strakes short of stern to balance lift. (or play around with tunnel compression to add lift)
professor_speed is offline
Old 07-07-2015 | 05:37 PM
glassdave's Avatar
Neno the mind boggler
looks like your X dim is awfully deep as well. I agree on the lifting strakes as well, seems like all the fast toons have 'em. You can buy them in pretty big lengths, a buddy of mine (lightning jet on here) just glued them on with some sort of DevCon and they have been there for three years
08 OPA High Points Champion
glassdave is offline
Old 07-07-2015 | 06:35 PM
It currently has lifting strakes did those the 1st yr I built it. They are yellow in the picture. They helped but I think I'm right on the HP limit (140hp) of them working. The LS should help that.
The bottom of the V is the same plane as the bottom of the strakes which is about 5" to the bottom of the toons. I think my X dimension is to low but I have heard pontoons like a deeper X because the have "dirty" water, lots of turbulence that screws up the prop.
That's why I'm thinking when I add the complete center toon (grey) part with a 12" pad along with lifting strakes and possible more lifting strakes on the outside of the outside toons I think I will be good.
I'm just a little worried about the current motor pod not having the 12" pad. If that will screw up anything. I'm taking the entire boat apart and flipping it over so I only want todo this once. Lol
Old 07-07-2015 | 06:51 PM
I was saying add strakes to the center pod if you kept the v profile to the front
Old 07-07-2015 | 07:07 PM
Ok, so your thinking not have the 12" bottom at all and just run the V with strakes?
Old 07-08-2015 | 12:42 PM
I wish I had something to add to the conversation to help you in your quest. I just want others who haven't seen your build thread to check it out! You sir are a craftsman in the truest sense of the word. I commend you on your talent and ability. Subscribed!
bulletbob is offline
Old 07-08-2015 | 01:38 PM
Thanks, sometime I wish I had the more money then brains part, but I dont so I'm left to figure out how todo things with what I have. Usally my own two hands and alot or research and a little luck.
I'll keep everyone posted, the "boat" isnt getting torn down till after labor day but then it will be balls to the walls to hopefully have it on the water before Ice is in otherwise it will be spring.
MIke
Old 07-08-2015 | 03:52 PM
Sorry for not having any engineering input, but if anyone could put you in touch with the toon or toons running around 100 mph at LOTO.
Feverz29 is offline
