Starting fluid
Old 07-15-2015 | 08:21 PM
Default Starting fluid
https://youtu.be/i1NDOw69CQE
activator40 is offline
Old 07-16-2015 | 12:01 AM
BUP
I will add there is no info in any marine owners manual nor never taught in any marine OEM schools to use starting fluid for anything related to marine. It is one of the dumbest things you can do to your marine engine plus the dangerous effects that can take place using it. And to add another dumb thing is seeing a ton of cans of sea foam and or starting fluid in the boat laying on the floor in the hot sun -
If you even need one drop of starting fluid to get your boat engine started / running - YOU have a mechanical problem that needs to be address and fixed properly.
BUP is offline
Old 07-16-2015 | 05:57 AM
Mbam's Avatar
Offshoreonly Advertiser
What BUP said big time!
Mbam is offline
Old 07-16-2015 | 06:52 AM
Yep, or it might go BAM
thirdchildhood is offline
Old 07-16-2015 | 07:59 AM
Originally Posted by BUP
I will add there is no info in any marine owners manual nor never taught in any marine OEM schools to use starting fluid for anything related to marine. It is the one of the dumbest things you can do to your marine engine plus the dangerous effects that can place using it. And to add another dumb thing is seeing a ton of cans of sea foam and or starting fluid in the boat laying on the floor in the hot sun -
Bup, you said it, You wont believe the bottles I find floating in engine compartments and stuffed away in the cockpits, unbelievable. A big no -no with mercury marine..
