Spark Plug Torque Setting
Old 07-20-2015 | 08:14 PM
Default Spark Plug Torque Setting
Changing my plugs on my 525 EFI, what is the torque setting? Owners manual does not say and I'm Googled out. Any advice on making this easier since there is minimal room between the headers? I'm assuming an extension on the socket, but wasn't sure if anyone had any tricks.
Feverz29 is offline
Old 07-20-2015 | 08:28 PM
I have never torqued a spark plug in my life.
JRider is offline
Old 07-20-2015 | 08:41 PM
anti seize on the spark plug and when your elbow pops all is good...
proboat-wes is offline
Old 07-20-2015 | 08:42 PM
SB
I see people, including mechanics, fk up NGK's all the time. They can't seem to get the jist of the crush washer they use. I love'm !
Edit in: they leave'm loose by mistake. Okay, stupidity.
SB is offline
Old 07-20-2015 | 08:45 PM
SB
I'm sorry OP.
GM says 22ftlbs on plugs in their cast iron heads. Got that from my Alldata subscription
Edit: I see you mentionmed 525, so it has aluminum heads. I use copper antisieze, just a small smear on end a thread or two down from the tip side. You don't want any entering the combustion chamber.
HArd to describe. Sorry.
SB is offline
Old 07-20-2015 | 08:47 PM
General rule of thumb, if they are spark plugs with a gasket, hand tight plus 1/2 to 2/3 a turn, tapered seat, 1/16 turn more.
4mulafastech is offline
Old 07-20-2015 | 08:49 PM
SB
15ftlbs on aluminum heads. Looked up Subaru and Toyota. LOL.
SB is offline
Old 07-20-2015 | 09:51 PM
on 525 EFI, merc service manual says 20 ft lbs.
HyFive578 is offline
Old 07-20-2015 | 10:35 PM
I go with German specs... good'n tight
swiss is offline
Old 07-20-2015 | 10:39 PM
Wobble's Avatar
SORE MEMBER
I had a Swiss friend that used that setting, he was also the guy that introduced me to time-serts, an item he seemed to use a lot of.
Wobble is offline
