what speed should I expect? >
Old 10-20-2015 | 02:06 PM
Originally Posted by superderek3
I'm not trimming out once on plane .
There is your problem. Report back RPM's once it is back on the water.
92nsx is offline
Old 10-20-2015 | 02:21 PM
that's probably my only problem - if that works then i'll likely get into my RPM range as well and all will be good.
superderek3 is offline
Old 10-20-2015 | 05:15 PM
I'm not trimming out once on plane but now recognize it's something i should be doing. I'll need to experiment with it. Boat is now winterized so it'll be a while till i can come back with test results.
Wow! Yeah that's your problem. Happy boating next season. but don't over trim. Find your best speed and rpm. Good luck
Drew555 is offline
Old 04-21-2016 | 11:34 AM
With trimming the boat hits 60MPH - much faster, @4400RPM!
Old 04-21-2016 | 01:36 PM
You need smaller props and more rpm. I 'd try 23 Mirage plus'
Griff is offline
Old 04-21-2016 | 01:40 PM
SB
I'd wait for him to have a little more seat time. Thi is his first time running it since being told about trim. Outdrive trim that is.
SB is online now
Old 04-22-2016 | 08:21 AM
Would smaller props make sense? I think these motors are rated for 4200-4600. 23p would probably put me over 4600 i'd think
Old 04-23-2016 | 11:35 AM
Everyone needs some trim... bro trust me on this...
Do you keep it in the water? Has the bottom been painted?
Whens the last time the engines were serviced/tuned up?
You using speed wax?
iliveonanisland is offline
Old 04-23-2016 | 12:44 PM
My bad. I just re read and saw they were 7.4's and not 454mags. Ideally you want to run 4600-4700 rpms at WOT to get the best performance.
Get some more seat time and see what you get with it trimmed out for max speed.
Griff is offline
