-   -   Which scanner? (https://www.offshoreonly.com/forums/general-boating-discussion/330037-scanner.html)
Expensive Date 08-23-2015 08:43 PM
Which scanner?
http://www.rinda.com/acro/prodlist.pdf
Above link, only will use on engine below, what is best for me?
05 496HO, Borrowed one last week did not find a code, was getting single beep over 4500 RPM then constant if I stayed in it. Now getting two beeps but not the every minute recurring, goes away if I lower RPM. I can not tell which engine it is, gut is telling me its the water pressure sensor but want to prove it. I have WP, not hot, and good oil pressure. thanks
vindicator101 08-24-2015 11:14 PM
It seems like everyone is going with this new one that has multilines for easier reading. Assuming it's a hand held your preferring.
http://www.rinda.com/techmatepro/
Expensive Date 08-24-2015 11:19 PM
That's what I ordered.
Expensive Date 08-30-2015 08:06 PM
Great tool, hooked it up Sat. No codes, but found a high water pressure event in freeze frame data. Traced it to some grass in the power steering cooler, water pressure is fine now. Ran at WOT for 5 miles no alarms.
