-   -   replacement windshield (https://www.offshoreonly.com/forums/general-boating-discussion/332548-replacement-windshield.html)
tim brown 11-18-2015 01:52 PM
who makes a replacement windshield for a 1997 fountain 35 Lightning?
Rik 11-18-2015 03:37 PM
Is this a flat one or one in a frame?
tim brown 11-19-2015 01:32 PM
flat plexy glass
blownincome 05-04-2016 01:51 PM
tim did you get your windshield issue taken care of ?
Rik 05-04-2016 02:29 PM
Aero Marine might make those.. Give them a cal 909-350-3543
SS930 05-04-2016 03:47 PM
If it's flat, go buy a piece of polycarb in the correct thickness. Use the old one as a template and make your own.
glassdave 05-04-2016 10:42 PM
Yep, I've made several. I dont think that windscreen is to awfully thick maybe 3/16 or 1/4 so it should cold form no prod. If you use polycarbonate you can bend the sh!t out of it without concern. Arcylic will also bend but some care is necessary.
Poly - much stronger but does not handle UV rays well and surface scratches easily
Acrylic - glossier and much more resistant to surface scratches but can crack under impact.
Neither cut easily with anything like a jig saw. Buy the actual laminate bit used in a trim router and use your windscreen for a guide template.
