Offshore raace hatches with gas struts
Does anyone have pics of a set up with offshore side by side engine race hatches that use Gas Struts? Trying to decide which way to go with our engine hatches
I took off the electric actuator and added gas struts to both sides. I screwed 3"x2" angle aluminum 10" long to both sides of the hatch and through bolted the lower end to the inside of the engine compartment (stainless washers inside and out to add strength) and I am a happy clam. I have never been a fan of the electric hatches, nothing I hate more than sitting and holding the switch while it taaaakkkkeeees forever (10 seconds) for the hatch to open. Now it is a 2 second deal. The struts costs much less than your going to be able to sell the system your taking off. The only problem is what are you going to do with the spare switch?
I've been looking into this also
there are struts available that have a locking sleeve to lock it in the up position -- nice option. Or there are struts the have a remote release button so it can be held in any position...
Ben are you referring to the old Cig style spring that you bend in the middle to get it to close and when its' open it is somewhat solid and straight? they used them on the Mistress cuddy entrance hatch...That seems very simple and effective...
I'm assuming locking pins are a must -- would you need them at both end of the hatches? or can you get away with a set just behind the rear seat so they are easy to reach?
Correct Craft's 230 and G series Nautiques with the transom walk through have the simplest arrangements for gas shocks...corner bracket on hatch and on the sill of the engine compartment opening where the struts are mounted to (one on each side of the hatch). I did a quick search for a pic but couldn't locate a clear example
Word to the wise.. go with much heavier (lbs) struts than what you think will suffice - you will be happier in the long run
