attn gaey kilofski
Old 01-15-2016 | 09:58 AM
RMPRam's Avatar
Originally Posted by Team Archer
Quite that's TOP SECRET stuff. And by the way I was the one that found the car here in CA.
Dan is correct.. He is/was my source for the car. Thanks again Dan.
Attached Thumbnails attn gaey kilofski-2014-05-24-10.00.18.jpg   attn gaey kilofski-2014-05-24-10.00.26.jpg   attn gaey kilofski-2016-01-12-15.05.48.jpg
RMPRam is offline
Old 01-15-2016 | 11:10 AM
Originally Posted by mike tkach
in doing some research i think the engine is a gmc called the twin six.i would love to find one to play with.gm produced around 5000 of them from 1960 till 1965.
GM produced these engines for Fire engines taking 2 Buck V6 ( about 300 cu inc each) and putting them together. The Hot Rod here has the BPM engine that is Italian Produced (Lamborghini?) that was available for a while. It is a SOHC V12- that they even installed in some of the Blue Thunders back in the early 80's. I saw one at Cat Cay pull in for fuel. The dock shook from those engines idling....
wannabe is offline
Old 01-15-2016 | 01:58 PM
RMPRam's Avatar
A few corrections. It is manufactured by BPM Marine (which is still in business and still producing the BPM surface drives) in Italy, (not Lamborghini) and it is not a SOHC engine. It has a conventional location for the camshaft and the hemi rockers are pushrod driven. The enclosed picture shows the engine in the 55 chassis in 2010 when the project was just started. Note the 6 48mm Weber DOHC carbs that were stock on this engine. After many attempts to make the Webers "work" we gave up and spent over 100 hours building a custom intake for 3 Holley 600cfm carbs.
RMPRam is offline
Old 01-15-2016 | 02:05 PM
RMPRam's Avatar
Here is a shot of the water "log", which is a section of 1.5"x3" rectangular tubing that the 10 water ports, 5 from each head, connect to and then flow to the front and eventually connect to the upper hose of the radiator. It is barely seen under the start of the 12 tubes that will eventually become the intake runners.
RMPRam is offline
Old 01-15-2016 | 02:08 PM
RMPRam's Avatar
Originally Posted by RMPRam
Here are some shots of the custom TriPower intake
Here is the start of the intake on top of the "water log". You are just able to see the front end of the rectangular tubing (water log) that will eventually be capped and a single 1.25" outlet welded on to connect it to the upper inlet of the radiator.
RMPRam is offline
Old 01-15-2016 | 02:11 PM
RMPRam's Avatar
nearly finished intake
RMPRam is offline
Old 01-15-2016 | 08:13 PM
scippy's Avatar
Beautiful to see it would love to hear it!
scippy is offline
Old 01-16-2016 | 05:50 PM
PigNaPoke's Avatar
http://www.thunderv12.com/
May interest a few of you... owner is local. As stand up as you can get.
PigNaPoke is offline
Old 01-17-2016 | 11:54 AM
RMPRam's Avatar
FYI, the engines, in the above link, are the ones referred to by Mike in post #6 and not the engine I have in my 55 manufactured by BPM Marine.
RMPRam is offline
