496 hydroloc  help. Help help >
Old 01-31-2016 | 06:13 PM
Default 496 hydroloc help. Help help
Plugs out can I roll it over with out disconnecting he ecu to prevent damage to it ?
tommymonza is offline
Old 01-31-2016 | 06:43 PM
so motor is a 2002 496 one of a pair in a formula cruiser.
water in 2 rear cylinders on port side . plugs out of the whole motor , riser off .
Question is can you crank it over without the wires and plugs atached.
will it damage the ECU without disconnecting it?
Old 01-31-2016 | 06:44 PM
yes turn it over no it wont hurt anything
class6 is offline
Old 01-31-2016 | 06:45 PM
yes what?
Old 01-31-2016 | 06:48 PM
I would roll it over by hand first then shoot wd40 in and give it a spin. If you have a teather just pull it out and hit the starter
class6 is offline
so there is no way the water came from the riser as i can see as it is not a open design like i envisioned on the old 454 i am used to
is this year motor 2002 known to blow head gaskets it has 500 easy hours on it.
Old 01-31-2016 | 06:55 PM
Does not have safety tethers.
Next idea?
Wobble's Avatar
SORE MEMBER
With plugs out, This is a good plan, after that check your oil for milk.
Wobble is offline
Old 01-31-2016 | 06:58 PM
just make sure the plug wires aren't close to anything and give it a turn.. When did you notice it was locked up?
class6 is offline
Old 01-31-2016 | 06:59 PM
i fired it up with the rear 2 cylinders plugs removed and it fired right up and blew water out
problem is i want to crank it and pickle it and i was thinking we are just drawing more water up through the outdrive intake and filling the cylinder again.
