Marine Machine with twin bravos >
Old 02-11-2016 | 11:35 PM
Default Marine Machine with twin bravos
I've located a Marine Machine ext steering and want to make sure it will fit before I do something stupid.
Anyone know how far away the transom plates mount from the gimble housing?
Specifically, distance between the outboard edge of gimble housings to the inboard edges of transom plates.
Did MM offer more than 1 cyl length for twin Bravos with outboard mounting?
How wide are the transom plates?
I'm hoping to squeeze them in between the tabs and the swim platform fairings. I only have abt 4 maybe 5 inches of space for the transom plate to mount.
If I did mount the transom plates say maybe up to an inch closer or further from ideal (horizontally), wouldn't I just loose a little throw or would it damage something?
Any help would be much appreciated.
zz28zz is offline
Old 02-12-2016 | 05:45 AM
Wobble's Avatar
SORE MEMBER
Horizontally speaking I'd agree. When I rebuilt my transom I hung the cylinders on the drive and without the hyd hoses connected and figured out the middle of their travel, where they reached the transom was the ideal for max throw/pull. Also checked that it would not be over turning.
It's going to be difficult to answer with out some installation drawings or the parts to mock it up.
Wobble is offline
Old 02-12-2016 | 10:45 AM
That would certainly be the ideal way to place the transom plates. Without the parts in hand, it's going to be a little trickier. I was hoping someone had the paper work they received from MM or had it installed already.
I got a PM from a member who is willing to measure his for me.
Anyone mounted their transom plates slightly inboard or outboard of ideal? How noticeable we're the effects?
zz28zz is offline
