Mercruiser 6.2 MX alarm help
I am not knowable about stuff at all I just stay in alot of Holiday Express hotels.
Alarms can start in as soon as the engine starts especially low water pressure and or bad water pressure sensor or IAC or its circuits. IAC controls IDLE but still comes into play if bad no matter of rpm.
Other sensors or short circuits can trigger the alarm as well at start up.
Your location
who is working on your app ?
Not a hard to fix for this but again if you keep on running it especially if it has a bad IAC can or will knock out the ECM 555.
Your location
Everyone on this board will say IAC the first time you mention you have a problem. They certainly are problematic but not to the extent the board would have you believe.
X2 to what BUP said, go get it scanned and let us know what it says. Even if the person scanning doesn't know what they are talking about we can give you a reality check.
Whoever scanned this needs to look in the history of the scan -
Who scanned the engine ? Do they have the experience of scanning marine engines and know what all the information means ?
What scan tool did they use.
If you have an alarm going off you have a set fault code of some sort as the scan should pick it up.
To find my water pressure sensor issue we had to run the boat with the scanner on it and watch the details and narrow it down. there was also no codes on mine. Took about an hour of getting out in the water and running around crossing off possible issues.
