Start to Finish: Building Our 50' Skater >
Old 04-01-2016 | 02:34 AM
  #471
BigSilverCat's Avatar
A few of the transmission housings. I will be able to take the upper back cover off the transmission while its in the boat. That gives me the ability to replace the clutch pack or put in a spacer to make it direct drive if we have a problem with the pump or valve body to just make it direct drive.
[ATTACH=CONFIG]553319[/ATTACH][ATTACH=CONFIG]553320[/ATTACH][ATTACH=CONFIG]553321[/ATTACH]
Attached Thumbnails Start to Finish: Building Our 50' Skater-transmission-7.jpg   Start to Finish: Building Our 50' Skater-transmission-8.jpg   Start to Finish: Building Our 50' Skater-transmission-9.jpg
BigSilverCat is offline
Old 04-01-2016 | 02:41 AM
  #472
Clutch piston, piston retainers and springs. And the clutch hubs.
[ATTACH=CONFIG]553322[/ATTACH][ATTACH=CONFIG]553323[/ATTACH][ATTACH=CONFIG]553324[/ATTACH]
Attached Thumbnails Start to Finish: Building Our 50' Skater-transmission-10.jpg   Start to Finish: Building Our 50' Skater-transmission-11.jpg   Start to Finish: Building Our 50' Skater-transmission-15.jpg
Old 04-01-2016 | 02:45 AM
  #473
Input shaft for the transmission. I am making the transmission really overbuilt. I don't want to have anything that can break when I'm 1000 miles from shore.
[ATTACH=CONFIG]553325[/ATTACH]
Attached Thumbnails Start to Finish: Building Our 50' Skater-transmission-16.jpg
Old 04-01-2016 | 05:56 AM
  #474
Wow - This thread just keeps getting better and better! That's the real deal right there!
Scagburner is offline
Old 04-01-2016 | 05:57 AM
  #475
Very impressive engineering & machine work.
Is this something you've designed yourself or are you manufacturing the parts you had someone else engineer to your specs & draw?
As you know we have a very strong partnership w/ Gene Haas & Haas Automation. Just out of curiosity what equipment do you have in your shop?
NASCAT is offline
Old 04-01-2016 | 07:47 AM
  #476
Nice work! Are you worried these will make a lot of noise being straight cut?
jvcobra is offline
Old 04-01-2016 | 09:12 AM
  #477
Plum_Crazy's Avatar
Originally Posted by BigSilverCat
Teeth cut into the gear, splined, hardened, ground, and coated for wear resistance and rust preventative.
[ATTACH=CONFIG]553307[/ATTACH][ATTACH=CONFIG]553308[/ATTACH]
You know, you could probably pay for the whole boat just by designing and manufacturing better Bravo XR gear sets and shafts.
Plum_Crazy is offline
Old 04-01-2016 | 09:15 AM
  #478
mxz
This is the best thread ever. Awesome job. I am also curious as to what kinds of machines and software you use to program them as this is what I do for a living also.
mxz is offline
Old 04-01-2016 | 09:51 AM
  #479
Think this is his set up: http://www.apex-mfg.com/p/contact.html
AZMIDLYF is offline
Old 04-01-2016 | 09:52 AM
  #480
getreal's Avatar
How long have you known Gene? My first Haas machine was serial # 63. LOL
getreal is offline
