Help! Need x dimension help !!!!! >
Old 03-28-2016 | 09:26 AM
Default Help! Need x dimension help !!!!!
I've got a 1993 42 executioner. ...converted from trips to staggered . 18 inch centers. 575 hp per side. Bravos.
Need to know where to set my X before we cut drive holes.
Reggie lll said to go 1 inch under bottom running 5 blade maximus.
Anyone have any input???
I'm worried this will be too high.....
2tonchevy is offline
Old 03-28-2016 | 09:32 AM
PigNaPoke's Avatar
I'd say Reggie III would be the expert on the subject.
PigNaPoke is offline
Old 03-28-2016 | 09:35 AM
My 2000 42 was set up by Fountain 1 above 18 crank center,s
575cat is offline
Old 03-28-2016 | 09:45 AM
Thanks guys. Just nervous lol....we gonna be putting the saw to the new transom ....trying to get it right.
I'm going with Reggie advice unless some other authority can make an argument to the contrary
Old 03-28-2016 | 11:06 AM
1" below sounds pretty conservative for reggie's typical suggestion. But closer to where I'd rather see a bravo setup if you want any longevity vs top speed.
Unlimited jd is offline
Old 03-28-2016 | 11:24 AM
Really appreciate the input. I've never set up a boat like this ..it's the first twin engine project I've rigged and first staggered boat. Just wanna make sure I have all the correct info
Old 03-28-2016 | 01:12 PM
Try to get in touch with Billyboat
class6 is offline
Old 03-28-2016 | 01:19 PM
14 apache's Avatar
Was this a speed master boat or bravo?
14 apache is offline
Old 03-28-2016 | 01:40 PM
Bravo .
575cat is offline
