Keeping bilge clean on boat lift
Although I have never tried it, was told to use powder laundry detergent and a couple bags of ice cubes in the bilge, then go out and run the hell out of it.
I use Purple Power or Castrol Super Clean, hose and shop vac.
I normally do not get any water in the bilge as everything is properly sealed and the cockpit is a self-bailing design that routes everything overboard via multiple thru-hull fittings. However, for whatever reason the damn anchor locker drains to the bilge! Brilliant! So I do get the occasional dirty water from there into the bilge along with the occasional bit of oil from an oil change (me spilling new oil), dust, carpet fibers, etc. It doesn't help that my lift, even though I have the arms mounted higher in the front than in the rear, runs slightly downhill back to front due to the dock flotation sucking b@lls. That makes everything want to run forward under the gas tank. I can actually climb down onto the lift pontoon and remove the drain plug but it really does no good.
I'm probably preaching to the choir on this one.
A couple of folks indicated that their bilge constantly has water in it - Just a reminder that each gallon of water is 8 pounds - so hauling around an additional 10-20 gallons of bilge "stuffs" can add weight to the boat quite fast - this coupled with the routine beverages can have some impact on the speed of the boat and fuel consumption. I have a number of friends that constantly complain on speed issues- but then I remind them of all the "crap" they are carrying with them and then the light bulb get lit.
3pointstar
3pointstar
I'm thinking about sewing some vinyl in the cover over the anchor locker to keep it nice and dry.
I assumed it was standard issue but maybe a previous owner added it.
My cig has the third little bilge pump wired with the starboard pump. The little diaphragm pump is on the firewall and the pick up is way down in the bottom. Kick the starboard on in manual and it sucks out just about every last drop. They do burn out though since it's just a water transfer pump (no oil or chemical resistance) but it works surprisingly well.
