Oil pressure sender
Old 06-05-2016 | 08:43 PM
Default Oil pressure sender
Does anyone know the part number for the oil pressure senders for my 87 Formula SR 1 with the factory VDO gauges. Thanks in advance
jim8860 is offline
Old 06-06-2016 | 07:21 AM
PDF format VDO catalog:
See page 14 for senders
http://www.nsifleet.com/pdf/VDO_Mari..._1990-2000.pdf
Speedracer29 is offline
Old 06-06-2016 | 08:59 AM
If you have twins make sure you order a dual station sender
chris302 is offline
Old 06-06-2016 | 09:05 AM
What, a dual station 357?? pics please
GLENAMY 242SS is offline
Old 06-06-2016 | 04:20 PM
Sorry brain fart on my behalf dual station is only if you have 2 helms. Sorry for any confusion.
chris302 is offline
Old 06-06-2016 | 06:21 PM
BUP
^^^^^That is correct ^^^^ they are for boats that have dual helms - example - one in the lower deck and one in the upper deck or 2 helms in a cockpit where ever that would be located - example- front & back or one side and the other side of the cockpit or however.
BUP is offline
Old 06-06-2016 | 10:04 PM
Thanks for the information... do I need what is the difference between a "floating" ground or a standard ground.. ?
jim8860 is offline
