Question on Hp vs Prop pitch >
Old 06-05-2016 | 08:43 PM
Default Question on Hp vs Prop pitch
If I added 125hp per motor how much prop pitch do you think that would account for???
32 Active Thunder is offline
Old 06-05-2016 | 08:58 PM
Rookie's Avatar
Probably the same prop. If you added more HP via NA and not blower then you probably need more RPM's to achieve that HP.
Rookie is offline
Old 06-07-2016 | 12:51 AM
I added about 60hp to 454 mag and it added 400 rpms. I kept the same prop and went from 5000 to 5400rpms.
Griff is offline
Old 06-07-2016 | 11:33 AM
Dave M's Avatar
Veteran: Navy
I went from 385HP to 425HP in a 24' boat and went from a 26P to a 28P bravo. Stayed around the same RPM, picked up 4 MPH.
Dave M is offline
Old 06-07-2016 | 11:49 AM
torque has a lot to do with it also.
Sonic24 is offline
