Any electronics experts?
Old 06-21-2016 | 09:27 PM
Originally Posted by DirtyMoney
Do not use an Sd card larger than 8gb or you will beat your head against a wall trying to figure out why it will not update.
Thanks Dirty Money, used a 2 gb card and had no problems.
hardcore is offline
Old 06-22-2016 | 09:41 AM
WARPARTY36's Avatar
Drive to arrive alive!!!
I fought this and fought this last year. Finally had the tech at PBC update it, and that was my issue. I guess bigger isn't always better.
WARPARTY36 is offline
Old 06-22-2016 | 05:44 PM
I do not want to even try to figure what the size of the SD card has to do with anything !
hardcore is offline
Old 06-27-2016 | 09:38 PM
Tracked down a poorly connected power wire into the fuse holder and a blown fuse . Possibly the wire was cutting in and out and maybe arcing which caused the fuse to blow? Anyways repaired the wire and replaced the fuse and things are working again. Pretty small fuse on that yellow wire, 3 amps. Hopefully this will clear things up.
hardcore is offline
Old 06-28-2016 | 06:16 AM
Sounds like you found it. Yes the fuse rating sounds about right. It would depend how many loads are on the back bone. Most go fast boats do not have a lot.
You should be good to go.
Double Rigged is offline
