k plne hose fitting, what is it?? >
Old 06-24-2016 | 10:02 PM
Default k plne hose fitting, what is it??
The hose from the pump to the thru hull fitting , thru hull end fitting.(older style 2 piece ram tabs) Its smaller than the fitting that goes into the pump. The hose on the outside from the ram to the thru hull threads in but does not tighten all the way (threads are tight but hose still loose).
phragle is offline
Old 06-25-2016 | 10:07 AM
phughes69's Avatar
I think the fitings are a brake flare. Could it be that there is no seat for the flare to seat against?
phughes69 is offline
Old 06-25-2016 | 10:33 AM
GB
http://www.offshoreonly.com/forums/general-q-20/
http://www.offshoreonly.com/forums/d...ng-budget-249/
GB is offline
