Ouch.. Boat fall from crane in marathon >
Old 06-27-2016 | 03:59 PM
Originally Posted by Tom A.
That was not poor rigging, that was structural failure of lifting hook mount.
The rigging was at a very minimal angle more than sufficient to safely lift up without putting a lateral load on the lifting points or needing a spreader bar.
You can hear the bulkhead and deck popping right before it lets go.
There is even a section of the boat that pulls out with the rigging.
I know a little something about rigging.
I agree the angle wasn't extreme (certainly not compared to some jobs I've seen) and my thoughts are certainly looks to be more a boat structural defect, however I was always taught to keep the lines as straight as possible hence the comment that a spreader bar wouldn't have gone amiss.
Waterboy123 is offline
Old 06-27-2016 | 04:46 PM
DRAG's Avatar
This may be a really dumbass question from a rookie, but on a boat that size why lift it? Why don't they just launch it like all us low folks?
DRAG is offline
Old 06-27-2016 | 05:13 PM
i was thinking the same thing,it seems to me like it would be quicker to back the trailer in and drive it off than lifting&setting it into the water.
mike tkach is offline
Old 06-27-2016 | 09:16 PM
LIFT POINTS, hardware, materials, center of gravity, load capacity, tag lines etc are all considered rigging.
Failed RIGGING was to blame when a lift point broke free from the load the crane was attempting to pick.
You a crane hand as well Tom?
dlange is offline
Old 06-27-2016 | 09:25 PM
glassdave's Avatar
Neno the mind boggler
Most times it much easier at certain venues plus a lot of racers just dont want to dunk the trailer in salt. In our case with the cat it had crash boxes and getting around a marina ramp can be difficult.
08 OPA High Points Champion
glassdave is offline
Old 06-28-2016 | 10:16 AM
Tom A.'s Avatar
Heavy Highway and Construction Company - Family owned (I'm a share holder) and in the business development end now. However I have run equipment since I was 12, ran through the field ranks up to superintendent, project manager, etc.
As for the how far do you call it rigging, its really splitting hairs when the certified lifting hook or eye is still embedded in the material itself that gave way. We had a similar situation on a precast concrete section that broke free. The lifting eye was still firmly embedded in a chunk of concrete that sheared off do to what appeared to be an air pocket in the pour. The final analysis was the rigging was 100% and the material it was lifting failed. To me this is the same thing. If you pull out a piece of bulkhead, the boat failed not the rigging.
Tom A. is offline
Old 06-28-2016 | 11:18 AM
I,ve known the correct answer to what happened all along .
SOMETHING BROKE !!!!!!
klaatutooyou is offline
Old 06-28-2016 | 11:51 AM
Turbojack's Avatar
Not a crane man here but I would think the load that was being applied to the hook not being a straight up load helped shear the bulkhead out of the boat.The bulkhead might have not given way if it was lifted straight up vs being pulled to the back of the boat
Tom, Your picture is lifting what looks like an I beam to me. I do not think there is a beam keeping the lifting points separate, is there?
Turbojack is offline
Old 06-28-2016 | 11:57 AM
I work at Arby's. I apologize for posting and wasting everyones time. I don't even own a boat.
dlange is offline
Old 06-28-2016 | 12:24 PM
Ryan Beckley's Avatar
Racer
Racer
BTW this is about a 15 year old RACE BOAT that we are talking about here, it probably weighs 8000# is was one of Fountain's factory built boats......
Ryan Beckley is offline
