Boat taking on water
Old 07-09-2016 | 05:14 PM
If it leaking with drives up or turned. It probably the bellows
class6 is offline
Old 07-09-2016 | 05:16 PM
SB
Originally Posted by scottgjerdingen
. Ironically the leak almost stopped with the drives down, it is with them up that I had issues.
Shift cable boot or driveshaft bellow.
SB is offline
Old 07-09-2016 | 05:27 PM
Craney's Avatar
Is it in salt or fresh water?
Craney is offline
Old 07-09-2016 | 06:47 PM
BUP
did he already post somethings rotted with boat ??? rotted transom and or bad transom seal - also possible tear in the u joint bellows.
BUP is offline
Old 07-09-2016 | 06:52 PM
So it is safe to say you totally ignored my advice to hire a marine surveyor before you bought this boat.
Some men you just can't reach, which is the way he wants it. Well he he gets it, a sinking boat.
sonicss42 is offline
Old 07-09-2016 | 07:16 PM
BUP
like I said - if you are asking about a water leak ?
http://www.offshoreonly.com/forums/g...stringers.html
BUP is offline
Old 07-09-2016 | 08:24 PM
rak rua's Avatar
Before someone gives you a nickname like Scott Sunkin, I think you'd better bite the bullet and get that boat off to a good shop. Have that leak investigated (silicone is an emergency repair to get the boat home) get another opinion on that transom and have someone check your issues with overheating.
It may cost you a bit, but spending money now can save you money further down the track. You knew when you bought it you could have to throw some money into it, and you were right!
Good luck
RR
rak rua is offline
Old 07-09-2016 | 09:23 PM
Is this thread for real?
Padraig
Padraig is offline
Old 07-09-2016 | 09:26 PM
jeff32's Avatar
Get. That boat out of water asap!!!
jeff32 is offline
Old 07-09-2016 | 09:40 PM
SB
Padraig
Yup, and the other 20 or so threads he's started recently.
SB is offline
