Is there a trick?
Old 08-02-2016 | 08:32 AM
Default Is there a trick?
Brass fittings are so darn soft I often struggle to loosten them without damaging threading to some extent. Is there a trick to not damaging them? For example drain plugs on the bottom of the exhaust manifolds and engine...those with a hex fitting, only if these are loose do I stand a chance of getting these out w/o damaging them.
scottgjerdingen is offline
maybe spray first with wd or pb blaster. Other than that maybe some heat
soldier4402 is offline
Old 08-02-2016 | 09:47 AM
I changed the pipe plugs on my headers to 1/4 turn water shutoffs so I can drain after each use. Works like a champ
MichiMike is offline
Old 08-02-2016 | 10:49 AM
Replace with stainless?
Get better wrenches?
Cole2534 is offline
Old 08-02-2016 | 11:03 AM
Why so tight? They're only holding water in under basically no pressure?
bobkatz is offline
Old 08-02-2016 | 11:08 AM
Stainless looks nice but it galls, not a better option. I think someone over-tightened things
JRider is offline
Old 08-02-2016 | 01:05 PM
c_deezy's Avatar
Use a socket or a flare nut wrench. If the flare nut wrench won't fit then heat it up and bend it to make it work. Put some anti-seize on it when you re-install.
c_deezy is offline
Old 08-02-2016 | 01:24 PM
agreed on the flare nut and anti-seize
kevinb230 is offline
Old 08-02-2016 | 02:21 PM
It [i[can[/i] gall, particularly when you have SS fittings threaded into other SS fittings, but if you use quality plugs and some nickel bearing thread tape you should have no issue.
Cole2534 is offline
