Leaving Power on the Table
Being the props are used and you don't know if they are stock specs, start there.
Are you seeing a speed difference with the 26's and 28's at 4900rpms?? You should see about 4mph more with the 28's.
Griff - your boat has twins - You can spin a bigger prop or run a taller gear than a single engine boat.
I lost 600 RPM when I went from 1.5 to 1.36 ratio. I am spinning a stock Bravo 28 to 6100 RPM but I have 800+ HP.
I just bought a labbed for me Bravo 28 from BBlades to see if I can get on plane a little easier and gain the 300 RPM I need .
I also think that the 1.36 ratio is holding you back. It takes torque to turn the higher ratio.
Agreed, the 1.36 gears is the problem. A 28p prop with 1.36 gears is like a 31-32p prop with 1.50 gears, to compare it to your old boat. You'd probably need to step down to a 24 or so if you wanted to keep the gears you have. To swap gears is ~$1000 I believe. I agree that you should be seeing a difference RPM wise between the two props, but only if they were both stock or both labbed etc. Since you don't know the history of the props, if the 28 is labbed, it will spin the same rpm as a stock 26. Should be about 200rpm between the 2 normally.
Why don't you find someone with a 1.5 ratio drive that will let you try it.
I lend mine out here in west MI. As long as they pay for the oil change and I go for a ride.
But I am running 1.5 ratio IMCO -2 shorty ( spare ) and a 1.36 ratio IMCO -3 shorty.
So the list of people wanting to try it is real short. Most people can't run a -3.
I was told that I was one of few able to run my prop shaft at 2 inches above the low point of the bottom on a 26/27 Daytona.
Based on gouge numbers, it should pick up to 5100rpm or so with a 24p prop. From what I understand, you should always keep the lowest gear ratio (highest numberically) until you run out of prop, then go to 1.36. With 1.36 gears, the prop is spinning ~350rpm faster at WOT than the 1.50 gears, so there are hydrodynamic effects that come into play with having a smaller prop spin faster. I'd be willing to bet that 1.50 gears and the right prop will net the best speed.
The OP needs to spend some time with the prop slip calculator.
For instance, you said you had this boat with 1.50 gears, 28p prop, at 5250rpm (lets assume 15% slip) would be 79mph.
To run 1.36 gears, 5250rpm, 79mph, and same 15% slip assumption, you would need a 25p prop.
Like I said, these are all theoretical, just math formulas. More comes into play hydrodynamically, mechanically (driveline losses), etc. Post this question on Riverdavesplace.com. Theres several guys with 28 bullets over there that could steer you in the right direction.
You're right, 600rpm difference at 6000rpm (~10% difference). I was talking prop speed which isn't very useful.
This boat with 1.36 gears, 28P prop, 4900RPM ran 79MPH.
Just posted on RDP as well. I figured I would start on OSO since it seems there is a larger contingency with 525's. However, not very many with singles. Great problem to have!
