-   -   Seven Marine vs Verado (https://www.offshoreonly.com/forums/general-boating-discussion/343586-seven-marine-vs-verado.html)
Sydwayz 01-03-2017 03:04 PM
Originally Posted by Double Rigged (Post 4515635)
I know of that incident personally and that was not a Mercury failure.
Yes, it was a rigging issue and/or metal failure.
But it illustrates the point of why the Seven Marine motors we developed.
Comparable power/performance with less infrastructure.
Sometimes 20% less.
Sometimes 33% less.
Gimme Fuel 01-03-2017 03:06 PM
Originally Posted by Double Rigged (Post 4515608)
Is it me or are the two outside propshafts missing????????
Well, I imagine the culprit of that might be a wide-beam boat doing high speed turns that leans enough to pull the outside props out of the water. Bouncing off the limiters on re-entry it fatigues/shears the shaft. Looks like the props are run fairly high as well exacerbating the issue.
Sydwayz 01-03-2017 03:12 PM
I look forward to the day when someone is bored with their Verado powered Cigarette CC, and clamps on some 627s.
Double Rigged 01-03-2017 06:49 PM
Not sure if you all remember but Nortech ran a 390 w triple 557's some time ago. Boat ran 88mph or so. At the time everyone was stoked. Now price out 3 motors at 60k each. 180k.
Nortech builds a 390 with quad 400's. Similar hp. Motors around 30k each. 120k total.
Seems like easy decision for me. By the way boat ran 100mph.
I have seatrialed many Intrepid's with 7 power. They are also louder than the 400r also. However there seems to be the cool factor of owing a boat with them as not everybody has them.
X-rated 01-03-2017 06:52 PM
I look forward to the day someone is bored with there Verado powered cat and bolts on a pair of 627's!!
Sydwayz 01-03-2017 07:08 PM
Triple 627 Seven-Marine Outboards would likely come close to matching that of the Quad 400s.
Also, did the Triple 557 boat have the T-Top on it for those speeds?
The Quad 400 boat did not have T-Top when it they set that speed record.
erik1976 01-03-2017 07:27 PM
The quad 400r boat that broke 100 did have the top on. The first quad 400r boat did not have the top on when it ran 97 or so.
Sydwayz 01-03-2017 07:48 PM
Thank you for the correction.
SB 01-03-2017 07:55 PM
Ooops just realied someone else posted pic here:
http://www.offshoreonly.com/forums/g...ml#post4515616
hogie roll 01-03-2017 09:40 PM
https://instagram.com/p/BO0qS8wgCqM/
