Engine Hatch Mirror Options / Tips >
Old 01-26-2017 | 06:21 PM
  #41
Originally Posted by VoodooRob
Received 2 sheets of stainless from Discount Steel yesterday. They were wrapped and sandwiched with particle board and then wrapped in cardboard. Shipped thru Fed ex ground no damage. This picture is the back of the stainless so ignore the light scratches, the front is covered with a mask to protect it. I also ordered a 100' roll of 1" Ultra High Bond 3M double sided tape, you have seen it as emblem adhesive in the auto parts stores. Will update once everything is received.
[ATTACH=CONFIG]564146[/ATTACH]
Looks good. Did you have them notch a hole for the ram mount or are you going to make that cut?
Crude Intentions is offline
Old 01-26-2017 | 08:56 PM
  #42
VoodooRob's Avatar
Not necessary on my boat, rams mounts are not close in the area, makes this very easy to do. Only thing I have to template is the fender mount on the starboard hatch. And yes I am fixing the rubber gasket that is coming off the hatch too!
[ATTACH=CONFIG]564156[/ATTACH]
Attached Thumbnails Engine Hatch Mirror Options / Tips-49653.57097b6dc715abaa54c880b5.xl.jpg
VoodooRob is offline
Old 02-05-2017 | 11:07 AM
  #43
VoodooRob's Avatar
Using 3M VHB double sided 1" wide tape, 100' roll so i'll have some left over. Also ordered adhesive promoter pads from 3M, they smell like rubbing alcohol but leave a slightly tacky surface. I feel it is very important to get as much of the oils/debris as possible off the backing of the stainless panels. Clean surface = stainless that sticks and stays put. Set the tape aprox 6" apart, thanks to Neil "HyFive578" for the tip. I installed port side, starboard side I had to template for the fender holder. There is no fun house, wavy look and that is a relief. The 18 gauge stainless is about as thin as I would go to avoid the issue. Will post final photos and total cost for the project once vinyl decals arrive this week.
[ATTACH=CONFIG]564462[/ATTACH][ATTACH=CONFIG]564463[/ATTACH][ATTACH=CONFIG]564464[/ATTACH]
Sorry for sideways pics, posting from my phone
Attached Thumbnails Engine Hatch Mirror Options / Tips-20170128_141430.jpg   Engine Hatch Mirror Options / Tips-20170128_141448.jpg   Engine Hatch Mirror Options / Tips-20170128_143307.jpg
Old 02-06-2017 | 11:00 AM
  #44
Looks nice!
ALL_IN! is offline
Old 02-06-2017 | 11:08 AM
  #45
Looks great Rob. That's exactly how I applied the VHB tape. That is NEVER coming off...
HyFive578 is offline
Old 02-06-2017 | 11:14 AM
  #46
VoodooRob's Avatar
Once the tape made contact with the 3M promoter there was no coming back and re-aligning. I agree with you, at first I was 50/50 about adding some set screws and washers for "just in case", definitely no need after feeling the bond.
Old 02-06-2017 | 11:30 AM
  #47
There is no need for screws. I've had mine on for three seasons already and through some very rough water; not even a slight lifting from the surface.
Old 02-06-2017 | 09:36 PM
  #48
Wow I wouldn't know what to do with all that room
1989mach1 is offline
Old 02-07-2017 | 06:46 AM
  #49
VoodooRob's Avatar
I will never own a side by side setup again. Staggered really makes maintenance and cleaning a breeze.
Old 02-12-2017 | 07:12 AM
  #50
VoodooRob's Avatar
Total cost for project: 2 Custom cut stainless sheets, 100' 3M VHB Tape, 2 Custom logos $380 all in. Starboard graphic is smaller to allow for fender holders.
[ATTACH=CONFIG]564679[/ATTACH][ATTACH=CONFIG]564680[/ATTACH]
While I was at it, had some deck and misc vinyl graphics made
[ATTACH=CONFIG]564681[/ATTACH][ATTACH=CONFIG]564682[/ATTACH][ATTACH=CONFIG]564683[/ATTACH]
Attached Thumbnails Engine Hatch Mirror Options / Tips-20170211_135024.jpg   Engine Hatch Mirror Options / Tips-20170211_134943.jpg   Engine Hatch Mirror Options / Tips-20170211_102705.jpg
Engine Hatch Mirror Options / Tips-20170211_132642.jpg   Engine Hatch Mirror Options / Tips-20170211_135408.jpg
