There should be a clear gelcoat so that you can see all the fiber :)
West Coast Gel-coat guys are amazing. Fun build to watch.
http://i1238.photobucket.com/albums/.../SBN_logo2.png Update... the stringers are being laid in the hull http://i1238.photobucket.com/albums/...hStringerA.jpg http://i1238.photobucket.com/albums/...hStringerB.jpg the deck...rear area http://i1238.photobucket.com/albums/...sion/deckz.jpg |
Thanks for posting the step by step. Question would the autoclave be used in this type of build, is it necessary or over kill
The type of resin for post-curing (autoclave) fully cures in temps higher than room temperature. So if they used resins that fully cure in higher than room temps then they should use the autoclave or the resins will not fully cure. The use of post-curing would have to have been decided prior to laminate and resin schedule design. The SV29's that were built prior to the molds going out west were all post-cured I believe. . |
Originally Posted by shueman
(Post 4521588)
Boat will cure for some 2 weeks ... very labor intensive and will be an "option" available on new builds only ...
Thank you for sharing that
Originally Posted by 14 apache
(Post 4522490)
What is the cloth being used? Carbon and ??? Thanks.
from the pics the laminate appears to be carbon-kevlar stitched, non-woven...the good stuff . |
Who has autoclaves to run this stuff?
Originally Posted by Keith Atlanta
(Post 4522504)
Post-cure and Autoclave is very different. During post-cure, it's essentially that. The mold and part is put into a big oven, such as powder coated products, to either further maximize the cure of the part or if epoxy resin is used it brings the resin up to its particular temperature it requires to cure. Autoclave is the process when the part in the mold is put under vacuum (vacuum bag) then at the same time while being under vacuum it goes into the oven/room that is sealed and the entire room is heated and pressurized. Essentially the part itself receives double pressure and when heat is also introduced it allows the resin/carbon to flow together on a molecular level becoming one. |
| All times are GMT -5. The time now is 09:00 AM. |
