Clean up after salt runs????
You are correct I don't use it on the sides, just to flush motor and outdrives. Most any dish soaps will, they are formulated to cut grease. I always use a auto soap to wash boat/cars/motorcycles.
In both my Sonic and our Pathfinder we flush each motor on the hose for 5min (bump throttle).
We hand wash every inch of the boat with soap and water, interior and exterior, and we spray motors down with WD40 (for the O/B we take the cowl off). Never once has a corrosion issue using this method.
When I lived in the area my solution was B&W Resorts in Isleton. Private enclosed storage, Annual slip rental, splash/retrieve with their tractor in fresh water. When you venture to the bays by the time you get back to Isleton everything is fully flushed. Tell Candi (owner) Arthur (Gary) sez HI.
I'm going to check with Merc Racing to see what procedure they recommend.
I keep hearing about flushing with Dawn dishsoap. How is this done? What does it do? I would not wash my boat with it because I'm sure it would strip the wax. I may wash the trailer and wheels with it.
Thanks for all the input.
looking back I don't miss that cleaning job at all lol.
for the salt away when you buy it the first time you buy the kit (liquid and dispenser) from then on just buy the jug of salt away, the dispenser screws onto the hose and then attach flush fitting or spray nozzle.
I flush the engine with just water every time and run salt away through it about once a month, I just put stainless marine exhaust on and after three years in salt water the stack manifolds looked as good as a fresh water boat.
I use dry-rack storage and if you have that available check into it to me its worth every dollar
Modern cowlings are very watertight. I would be hesitant to rinse under the cowlings.or gunk up everything with wd40.
My dad's 14 year old 5000 hour Florida saltwater never been flushed Yamaha 225 looked like new under the cowling when I sold it last year.
Back in the day when I was in the parasail and jet ski rental business we used to rinse and flush the motors than douse them with wd40.
It made the motors such a mess after a while , so than we switched to BoShield which is like a wax coating.
That made the motors look like crap
Best thing we started doing was nothing at all. All the moisture from rinsing the motors were causing more corrosion than just leaving them alone.
