switching from a 454 to a 383. Thoughts?
There is no replacement for displacement. Looking at standard BB to standard SB (stroker) I would go with the BB every time. Since your repowering I would go with a 502 crate motor and not go with brand new drop in, because you would be looking a smog stuff. There are several folks here which have some drop in ready blocks on the swap and classifieds
The 454 will have more torque and prop turning ability at cruise speeds. Although the 383 may make more horsepower, it would be up top which sounds like not what you want. Go for a 502. Add a 100 horse and that much torque.
I am going through the same decision process right now. Replacing a 454 on a 24' pilot house that weights 7000lbs loaded.
The 383 sounded appealing, but I believe the loss of torque at low end would offset any efficiency. So for me, it is a no...
A lot of people are hot on the 502, but I do not see how it would be any more efficient, and might even cause outdrive failure problems from the increase torque and HP, depending on your drive. for me...it is a no
So after coming full circle, I was down to the 454HO (385HP) and the base 454, or a Vortec 454. The HO model will have power at the upper end, where I hardly go, so it is out now as well. Sad about it, because I love the internals. Even thought of buying it, and swapping off the heads for oval port ones, and a torque focused cam. But then, I am looking at a total of $8000. not bad, but much more than the base 454.
The base 454 or vortec is the easiest swap. They will be the most fuel efficient. At $3800 for a rebuilt, it is 1/2 the price of the HO. For you, I would add in the closed cooling system, and run for 2-3000 hours if you care for it.
