Scarab 29 Top Speed
Old 04-24-2017 | 01:36 PM
TYPHOON's Avatar
Originally Posted by CLASSIC MUSCLE
Yes, I got the boat from NJ I was looking at. It's on Lake Norman now, in North Carolina, and will also be seeing time in Tampa, FL. I think the props are Mirage Plus but I'm not by the boat right now to 100% confirm. Drive gear ratio's I'm not sure. How do I check that?
You can count the teeth on your gears if you take the drive off or put motor at top dead center on the timing mark, put in forward gear, mark you prop location, rotate the motor with a breaker bar one full rotation, see how far your prop traveled (should be 1 1/2 turns) That's a 1:1.5 gear. That's how they used to tec our boats in APBA Factory classes. Don't forget a 1.65 gear is pretty close.
TYPHOON is offline
Old 04-24-2017 | 01:47 PM
Might be easier to pull the coil wire or plugs on the coil, put in gear, then jump the slave solenoid. Crank it over several times counting the prop and the crank
Edit: make sure to feed the drive water when doing this, no reason to take a chance
AllDodge is offline
Old 04-24-2017 | 04:24 PM
Couldn't you just take the drive off and rotate the drive shafts one turn
jwws9999 is offline
Old 04-24-2017 | 06:19 PM
TYPHOON's Avatar
Yes but rotating the engine only takes about 5 minutes at best with a friend.
TYPHOON is offline
Old 04-24-2017 | 06:24 PM
TYPHOON's Avatar
My only concern would be bumping it exactly one rotation. A 1.65 gear could be confused if you were not exact IMO. I'm not a mechanic just someone who has been through Tec many times in APBA LOL
TYPHOON is offline
Old 04-24-2017 | 06:28 PM
Rotate the motor at least 10 times, this will be easy to determine by dividing the crank vs the prop
AllDodge is offline
Old 04-24-2017 | 07:16 PM
1997 Scarab 29, Twin 383 Mercuiser Mags (350HP each, stock), Bravo 1's with 23P Mirage props spinning out. I am only getting 65-66 mph @ 4,900 RPM's with drives out, tabs up. Shouldn't this boat be going faster? This model supposedly does 67-68 mph with stock 350 MPIs which I believe were rated at only 300HP vs the 350HP of my engines. Suggestions on getting more speed? Different props? I feel this set-up should be going 72-73 mph.
your Scarab should be around 70mph. I have a 2001 twin small blocks 23 mirage plus, stock it ran 67-68mph at 5100rpm. As TRC2 said, check for spacers, mine had them also, would let the tabs come up to parallel. They are 383's now and best it has run is 74mph. I have 3 sets of props that "I" have had the check to be true and correct. 23 mirage plus, 25 mirage, 26 hydromotive 4blade. the 25mirage have been redone again to mirage plus specs. in next few days I will run all 3 sets and get good numbers of RPM, Speed, Slip.
01scarab29 is offline
Old 01-27-2018 | 11:39 AM
Scarab2323's Avatar
What’s your top speed I got a 29 with motor with each putting 355 hp I hit 64 bravo drIve 23 mirage
Scarab2323 is offline
Old 01-27-2018 | 09:20 PM
I believe the motor spins 1.5 times for 1 prop revolution if I am not mistaken.
28cigarettess is offline
