I bought a set of 16 footers for like 20 bucks at harbor freight . I also ordered remote jumper posts from summit racing and mounted them in an easy to reach location. My hatch is hydraulic and batteries are in engine room. If they go dead I'm kinda screwed even though pump is mounted outside in a compartment. Cant really put that much power through a tiny gauge wire so opted to remote posts. Happy to say since I did this I haven't needed the cables lol!
^^^ Did you check to see if those cables are rated for the amperage needed and length? When pricing adequate cables, I was in the $80 range and not at HFT.
Thought about cables then killed that idea for a jump box that many on OSO are using. I rather be self sufficient , so between that, Boat US towing and battery switches, I feel I'm covered. |
Originally Posted by Dave M
(Post 4548950)
I don't carry much in the line of tools these days, but I still carry a set of jumper cables. That said, in 20+ yrs. of boating, many of those yrs. with a single engine and one battery, I only used them once.
I keep some on the boat, but one day took them out to use them on the farm for starting the backhoe. (They are long and heavy duty) I then forgot to put them back on the boat and lo and behold, ran the battery dead the next weekend. We found some cables, but they weren't heavy enough to get enough juice to my boat to turn the motor over fast enough and run the electronics to start it. That was a long tow back to the ramp. Quality cables aren't cheap, you need really, really heavy cables to go 20' and start a fuel injected big block. .. [ |
(Post 4548878)
in theory, with a multiple battery system that is properly kept and managed, you should never need one. on a side note you should also never run with the battery switch in the "all" position, that is only for starting purpose. if you are one of those guys that runs in the "all" position. . . . . . better pick up some jumper cables :D
So my wife's boat says to never move the switch while the engine is running or alternator damage may occur. I have always moved the switch from "all" to "2" after I throw anchor before cranking up the tunes. Is this wrong?
Originally Posted by ChaseO
(Post 4549102)
I have a single engine boat with dual batteries. I always run "all". I park and listen to the radio on all as well. Never have an issue. My diesel truck has 2 batteries wired the same way. I dont get why its an issue.
^^^^Dual engines, each has a battery switch...put on all combines the two motors.^^^
Originally Posted by 79formula
(Post 4549195)
(Post 4549195)
Single engine with two batteries, when you anchor its good to switch to one battery so if you have any problems, you still have the second battery available. RR |
| All times are GMT -5. The time now is 10:50 AM. |
