outdrive project
Old 10-14-2002 | 10:36 AM
Goody76
Sand them down then use mothers aluminum polish and a buffer-you will get the "polished lower" look without spending al the loot. And in my opinion not does it only look nice but it is also alot smoother(less drag as long as you keep up on the polish) through the water. Lets face it we will take any extra mph's even if it is a tiny fraction!
Old 10-14-2002 | 10:58 AM
JUSTONCE's Avatar
I HAD A TRS WITH SALT WATER PITTING AND DESPITE SANDING AND REPAINTION WITH A QUALITY PAINT AND SEALING IT WITH CLEAR ANTI FOULING IT STILL CORRODED FROM UNDER THE PAINT, MAKE SURE YOU GRIND ALLL THE COROSION OUT SO ONLY FRESH ALUMINUM IS EXPOSSED.
JUSTONCE is offline
Old 10-14-2002 | 11:14 AM
JUSTONCE's Avatar
sorry about caps, not yelling
JUSTONCE is offline
Old 10-14-2002 | 11:36 AM
formula31's Avatar
And if your ever gonna leave it in the water again, dont use imron. Proper prep is a lot of work and if corroded, rarely successful without bead blasting and filling. If I were you, Id send them to Doller Marine. Ive heard good stuff about there coatings and prep work.
formula31 is offline
Old 10-14-2002 | 11:54 AM
JUSTONCE's Avatar
i concur ive also heard good things of thier work
JUSTONCE is offline
littledcsrodshop
03-28-2007 08:39 AM
260
0
08-06-2006 08:58 AM
Wateronthebrain
09-14-2004 07:37 PM
CHAOS REIGNS
5
12-03-2002 12:48 PM
scarabrick
11-27-2002 12:37 PM
