Merctrans
Old 06-11-2017 | 10:02 AM
Default Merctrans
Does anyone know what the letter designations mean on the mcm models ? Mcm-abcde
Carrera 80 is offline
Old 06-12-2017 | 12:00 AM
hblair's Avatar
Call Kirk at kc marine, he's knowledgeable, he'll know. Google him he has a website.
hblair is offline
Old 06-12-2017 | 05:42 AM
Thanks. Appreciate the info.
Old 06-17-2017 | 03:43 PM
Default Merctrans
Hi, Kirk at KC Marine here. Just so everybody knows. Any given a,b,c,d or e MercTrans internal components are interchangeable in any given case. Given the age of these transmissions, I see a constant mix of internal component changes; as "somebody" has likely been inside before, and mixed parts. So, in reality the tranny tag (abcde) means nothing until you get inside and see. The problem arises in some design changes to the input and output shafts. Unless the proper components are matched, it spells disaster. My website has dimensional drawings of the different shafts.
The "major" issue is the oil pump key size. The a,b and some c (if original), have a very small support key, and have made hundreds of higher horsepower, and "loaded" transmissions a casualty ( oil pump gears break).....It is important to have the larger keyed pump gear and input shaft. In relation to this is often the fact that, upon repower the crankshaft support bushing is left out of the end of the engine crankshaft. The mistaken assumption is that the flex plate supports the input shaft. The extension on the input shaft "must" be supported by the additional bushing. The original bushing is nla. Get a B50-HD bushing and machine the OD to 1.707"....It fits chev perfectly
rufusgrouse is offline
Old 08-11-2023 | 11:08 AM
Default Merctrans A,B,C,D or E...
What is your website address? I would like to see your technical drawings for Merctrans. Can I replace an MCM-E with an MCM-A? Thanks
Kristian13 is offline
