525 EFI fault code question, please help >
Old 06-29-2017 | 08:50 PM
Default 525 EFI fault code question, please help
Looking for a little help. Short story is I had a alarm go off this past weekend on a 2005 525 EFI w approx 160 hours. Motor was running great prior to alarm and during. No reduction of power and running smooth. 5 beep alarm. Scanned the motor and had 3 fault codes that I need help with. #77 cam sensor, 17 idle map str, and 21 ect overHT. My question is, should I simply replace all three or is there a sequence I should try so as not to buy unneeded parts (the damn cam sensor is very expensive, $700 ish). Also, any issue with using a ac delco cam sensor that is much less expensive. Any help would be appreciated. Thanks in advance.
mpick1127 is offline
Old 06-30-2017 | 08:16 AM
Based on my experience with my 525's...
Did the alarm go off at higher rpm or as you were coming off plane/idle, say less then 2,000rpm. If off plane or idle, replace the MAP sensor. also, do not throttle down at a rapid pace because that will cause a map code. I doubt it is the cam sensor.
joew. is offline
Old 06-30-2017 | 07:06 PM
It happened after running. I had come off plane and was idling under a bridge when the alarm started. I appreciate the feedback. Thx
Old 06-30-2017 | 08:08 PM
On Time's Avatar
Joe your boat looks fantastic
On Time is offline
