Transom lights.. Budget
Old 07-03-2017 | 07:07 PM
VoodooRob's Avatar
Originally Posted by flatlanderbill
Excellent question Buck!
Pretty much when your moving the lights are illegal everywhere that we boat. Is it enforced where you boat is the question.
VoodooRob is offline
Old 07-03-2017 | 07:43 PM
How about a set built into a pair of drive showers?? One less hole to drill below the waterline....
Powerquest230 is offline
Old 07-04-2017 | 07:54 AM
I have seen brackets that mount to the top of your trim tabs then the wire gets routed up above the waterline...
alindquist is offline
Old 07-04-2017 | 12:26 PM
I do not know why those lights would be illegal does not make sense.But if you are looking at a way to put underwater lights cheap and without drilling what about the ones that go in the drain plug, they are $50 each you could buy 4 and replace them when they break if they do.
20W SUPER BLUE 1400 LUMENS GARBOARD LED BOAT DRAIN PLUG LIGHT UNDERWATER 1/2 NPT | eBay
turbos230 is offline
Old 07-04-2017 | 01:57 PM
Indy's Avatar
Member #154
20W SUPER BLUE 1400 LUMENS GARBOARD LED BOAT DRAIN PLUG LIGHT UNDERWATER 1/2 NPT eBay
Those look great, I'll keep those in mind!
Indy is offline
Old 07-05-2017 | 03:47 PM
bigboat28's Avatar
Originally Posted by VoodooRob
I installed 3 Dagon lights. They are RGB and work off a remote control or phone wi-fi app. The colors are very good and they have a lifetime warranty against defects. Total was under $700. They are a good product and priced well. I struggled with this for a year and my decision fits what we need out of transom LED. I would post a photo, but doing so from a phone on this newer format sucks.
https://www.boatpluglight.com/collec...-transom-mount
Installed two of these 8000 lumen lights on the trim tabs, 199$ each and very happy.
bigboat28 is offline
Old 07-06-2017 | 04:54 AM
As to the legality of it yes it is illegal. The reason being any color can be misconstrued for a different light. It doesn't seem to be overly enforced but even on our work oats we have had coast guard vessels radio us and have us turn lights off. This is guide from them that kind of explains it.
http://blogs-it.cgaux.org/media/user...v%20Lights.pdf
Crude Intentions is offline
Old 07-08-2017 | 05:26 AM
Interesting as I just boated for the 1st time at night, on a river with only day boards as guides and 1/2 mile apart at best. Visual identification of boats with only the required red/green and aft white light was a joke when adding in the shoreline lights. Coming up on boats from the rear (I was traveling 25 mph, barely on plane) with transom lights on it was much easier to identify their heading. When I install mine I'll be running with them on and will gladly take the ticket not to get rear ended.
In addition, had I not been using the Navionics Ipad chartplotter/gps with my route to my destination traced to follow back and my heading line on. Without it I feel I would have been completely blind. That and the handheld spot light to confirm day board location were absolute necessities.
Tractionless is offline
Old 07-08-2017 | 07:45 AM
VoodooRob's Avatar
I get what your saying and completely understand your point, by the letter of the law it is illegal to have them on while under power. Again, enforcement varies just like exhaust and stereos.
Old 07-08-2017 | 08:14 AM
SB
I boat a lot at night...trick is to keep all interior lights off in cockpit...especially anything on the dash....either by switch or towel....this is especially true when any humidity in the air. The resulting 'halo' can blind you. Sure. all the bright LED lights are cool when you are hangin out....+ other boats can see you better....but can you see when underway ? That is the trick.
I would like to blow up all the dumb azz docks that the owners think it's cool to have red/green lights on the end of them.
SB is offline
