silent choice question
so I want to add silent choice to my boat,,boat has merc 496 HOs,,found a couple of used set of off 502s but was told they are different and will not fit a 496,,does anybody know what the difference is?
so are you saying the difference would be in the length of the tube going to the Y pipe? because I would think the angle would be the same because the Y pipe is the same for both applications,kind of what I was thinking
Its probably the length of the pipe going to the Y pipe. When I went from stock manifolds to Eddie marine I had Corsa add some length to this area. Later during my rebuild had to go to even higher exhaust so I removed the diverters and set them on a shielf
the Y pipes are allready there so I thought it would be a easy install,,
thats what I was thinking,,If that is the only difference I should be able to replace the 4" hose that is between the Y pipe and the diverter with a longer piece ,right?
[QUOTE=Knot 4 Me;4568092]Just going off of past visuals I would think there is a difference in the height of the exit points of the risers and possibly even a bit of the angle. Not sure just guessing those would be the differences between the two. Surprised your Fountain did not come with silent choice yet they installed and then blocked off the y-pipes. I've never been a fan of the pipes being there and capped. Just makes me nervous
