Can I start my engine dry? (out of the water) >
Old 09-04-2017 | 05:17 PM
Default no water start up
I personally would Never Start an engine without coolant of some kind, Period. It does not take too many seconds to heat a cylinder and remove tension from rings. Cylinders, Pistons, Rings, all need to be lubricated and cooled properly. Temp Does shorten engine life drastically. Not to mention the sea pump commonly has a plastic housing, with the rubber impeller. That will get hot instantly and start to melt the plastic, tear the impeller. Just my .02 I share this info weekly with my customers.
29 FOUNTAIN FUN is offline
Old 09-04-2017 | 08:13 PM
rak rua's Avatar
Good info, here's a few of the above suggestions answered. (sorry if it sounds negative)
Dont want to carry a battery home after every use or carry a booster pack, that's why I went with the dual batteries.
Boat is stored under cover so a solar panel/charger might help, something to look into.
I'll check for the Mercathode wiring.
The marina staff launch and retrieve (Marina policy) so backing her in and out on the ramp is messy.
I'm having her moved to a spot right next to a tap so I'll probably go with a quick flush the day before I want to take her out. Might look into a flush kit, a lot easier than the ear muffs. It's salt water use and flushed every time so a flush kit wouldn't go to waste.
Cheers,
RR
rak rua is offline
Old 09-04-2017 | 08:40 PM
Originally Posted by rak rua
I don't use my boat very often and always worry about flat batteries. Volt gauge is only an indicator, the only way I know for sure my engine will start is by hitting the switch.
Can I start it totally dry (no hose) and run for a 4-5 seconds just to be satisfied it will fire up when she goes down the ramp? How long is it ok to run before damaging the impeller, water pump and anything else.
It's a 496HO with Bravo One X sterndrive.
(I know a battery charger would solve the problem but where I store the boat, I can't hook up to mains power)
Thank for any answers,
RR
We always fire the engines in the shop before we go boating. They both run for about 5 sec. We have never had any issues with impellers. Last thing you want is to tow to the launch ramp and find out you have an issue.
BenPerfected is offline
Old 09-04-2017 | 09:29 PM
I would look into adding a sea strainer they usually hold enough water in them to fire it and run it for tat short of period.And could save your impeller if you ever suck up some trash
Riley0114 is offline
Old 09-04-2017 | 09:49 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I would not do this.
Sydwayz is offline
Old 09-04-2017 | 10:23 PM
rak rua's Avatar
When you back her down a steep ramp and start her up, chances are the impeller is dry anyway when it first starts to spin - unless you float the boat off so it's sitting lower than the waterline.
Correct?
rak rua is offline
Old 09-05-2017 | 12:30 AM
Originally Posted by beckmwi
I always crank it till the motor catches before going to the launch. less than 1 second of run time. No issues with the impeller-
Same here with no issues although I do change the water pump every year. If the batteries seem fresh enough I won't even wait for it to fire. It pukes a good deal of water out of the pipes on that split second burp so it's good to know that it's not dry for that moment of movement.
Baja Rooster is offline
Old 09-05-2017 | 09:41 AM
That's something like what I expected to read, thank you.
Jumper box vs dual batteries was another thread I started. I went with dual batteries - and still worry she may fail on 'boating day'. I just don't use it often enough....
RR
Hey RAK, Surprised nobody else stated the obvious but here goes.................. USE IT MORE OFTEN ! )
Excess is offline
Old 09-05-2017 | 11:19 AM
I just watched a guy do it yesterday and let it run for like 10 seconds. Personally, not something I would ever do. Only takes like 20 seconds to burn up the impeller. Like others have said, Keep in on a trickle charge at home and if it's dead at the ramp, pull back up and deal with it then. I happen to have a spare battery that I keep on a trickle charge at home. I throw it in the truck every time I head to the lake just in case. Either that or I also have a jumper box that I keep in my truck.
MonkeySea2 is offline
Old 09-05-2017 | 11:28 AM
Have done it for years with no issues on mine. Always start, run for a second or 2, then shut off.
Baldie is offline
