Originally Posted by Screaming Eagle Boats
(Post 4589057)
We are talking with a potential customer on one now that would be widened 24". We will see where it goes.
(Post 4589093)
118". Thanks
Wow nice when you go wide body magical things happen 24" + 118" = 142" = 11 ft 10 = yummy! I think that'll be good enough for the 120 club with twin 400R's! . |
First I wish you guys the best of luck as well. But having an outboard powered cat and having run other 400r boats as well having driven some of them Dale is right. Being in the marine industry the numbers on O/B cats are very subjective and can vary by huge amounts due to load, location etc. The 400r takes forever to make full power and you need miles to achieve top speed. As a HP O/B cat enthusiast it is great to see other manufacturers coming to market with new stuff. It can only help our industry and get mother Mercury to build that next generation high HP Outboard.
Originally Posted by noli
(Post 4589096)
Wow nice when you go wide body magical things happen 24" + 118" = 142" = 11 ft 10 inches fun! I think that'll be good enough for the 120 club with twin 400R's! . |
Originally Posted by Double Rigged
(Post 4589138)
Originally Posted by Skater30
(Post 4589276)
Widened tunnels do not make cats faster Noli......Garth and Jim proved that in Garth's classic 36.
there's a whole recipe of things to do in addition to widening the tunnel of a cat to make the cat perform better. but even if the widebody doesn't increase performance, a widebody just looks so awesome, is more stable, can seat more passengers, easier around the docks because the motors are further apart, and can add walking space around the outside of the windshield. . |
(Post 4589138)
Best of luck to SEB on this new venture. Subscribed.. |
Noli, I appreciate that you keep everyone up to date on so many of the projects in this industry but I've got to ask what's your background in marine engineering when you say things like there's a whole recipe of things to do in addition to widening the tunnel... While I'm sure there are ie step placement, sponson width, tunnel depth, etc what are they planning to do with THAT hull to get it there, if there was a magical formula to add speed without negatively impacting other aspects of handling the existing manufacturers would all be doing it. To just say the wider hull and 400's will surely get it to 120 is kind of silly, if that's the case would widening it 36" get it to 130?
As for maneuvering around a dock, that's subjective. The motors are plenty far enough apart on a standard beam to have perfect control at low speeds, the extra 2 feet won't make a difference there but could complicate things in tight spaces and it may not fit in standard slips anymore, especially on a lot of lakes that aren't expecting wide offshore cats. I've been in plenty of slips that a 12' beam wouldn't have fit and had to (wanted to) have spotters at the corners because I was so tight in a marina when trying to spin around. Do I like the wider cats sure but they're not a fix all or better in all circumstances. Having run with several existing 36 Spectre's with much more than 800 total horsepower you're going to have to work some serious magic to get that hull to 120 with stock 400's. Am I excited to see it ABSOLUTELY but I also don't think I'm being unreasonable to be skeptical. Being realistic with goals and exceeding them is I think a much more practical approach. IMO if you can get that hull to be an honest every day 100mph boat with fuel and 4 people you'd have a wave crushing super fun boat and I think that's probably more realistic but good luck... |
Originally Posted by mlb75
(Post 4589543)
... what's your background in marine engineering ...
MLB, I'm a software engineer by trade. I wish I can recite all of the things that DW and Arnaldo spoke about when they were discussing the changes they did on the molds. I don't even know if recipe is a technical word, I just used it here. One thing I did notice is that to make a cat run better, it's not just cutting and widening a hull. To increase performance on the widebody cat, there were terminologies like compression, CG, lamination schedule, windshield rake, etc that were tossed around. Maybe I should have recorded them so you can decipher their language and share here...but then I would proly be sharing info that they don't want shared. It looks like we're going off topic here and I apologize to Todd (SEB) for "helping" to hijack this thread. Now back to the SEB 36 . |
