Banging, clunking and thumping. Driveline problem 496/Bravo
#51
If the front of the engine has dropped down due to the front mount lower nuts backing off it will pinch the input shaft in the coupler and can be all but impossible to remove the drive. Have had that happen to me on a previous boat. Drive would not come off until I lifted the front of the engine back up. It doesn't take much movement either to pinch the drive in place.
#53
Service report has come back, uni-joint, coupler and alignment all ok but will check the last two again before refitting the drive. Quote for bellows and gimbal bearing sounds very cheap, about 420 USD. I'll check they are using OEM parts, they always have in the past. (To convert to USD, divide by 32)
RR
#54
All fixed today.
Damn hot so it's hard work 'on-site', no luxuries like a stand or trolley for the drive so I stocked the ice box with water and M150 (like Red Bull but better).
Tools looked pretty crude, simple input shaft (or similar) checked alignment, spot on. While they were there I had them change the impeller too. Difficult job with poor access to remove the pump. I suspect it's never been touched in 10 years and the old one (pictured) didn't look any different to the new one. Preventative maintenance is a good thing but this time, it was a waste of money. Bought some peace of mind but I'd happily trade peace of mind for a few drinks with a pole dancer at my local! [insert glassdave's avatar]
OEM parts used for everything.
Water test went perfectly, the guys enjoyed it, don't see many sports boats here.
Than you OSO.
RR
Than you OSO.
RR
#55
Some marinas in the US have probably charged your invoice amount for the same work without dividing by 32.
Looks good. I don't envy those guys horsing that drive on and off with no drive cart. Been there/done that in a marina parking lot once for an emergency shift cable repair and it sucks.
#56
All fixed today.
Than you OSO.
RR
Than you OSO.
RR
#59
RR
#60
2 guys have driven to the marina 3 times and including all their travel time (around 2 hours) I get charged 5,000 baht, or about 150USD.
