Transmission on a turbine, anyone ever try it? >
Old 12-29-2017 | 05:05 PM
Default Transmission on a turbine, anyone ever try it?
The disc break / Crashbox setup is just about the only part of my boat that I think could use a little help. The brakes tend to get hot if you over use them, and they are messy.
With the new 72L-HP on the market, I feel like that should be able to hold up to the punnishment.
Anybody try this yet? I know it's a small group that run these things, I'm just trying to not reinvent the wheel if it's already been done.
Thanks ahead of time for your input!
Tom
Tborisch is offline
Old 12-29-2017 | 08:24 PM
I think the SCS crashbox is the only thing that will handle the torque, I wouldn't like to try a clutched transmission behind a turbine if the clutches start to slip or fail your into an over-speed situation of the N2.
999JAY is offline
Old 12-29-2017 | 09:26 PM
Sadly I know too much about overspeed issues of turbines. Dealing with one at work right now...smh.
1MOSES1 is offline
Old 12-30-2017 | 08:12 AM
BigSilverCat's Avatar
There are a couple turbine boats that have my two speeds in them. They worked good because it would idle at a lower speed in low gear and it did not shift as hard as the crash box clutch
I'm sure the new Bam trans would work. The only problem they would have is if the turbine output shaft slowed down too much which would cause the trans to loose oil pressure and slip the clutch, I used an accumulator bottle to smooth that transition
Attached Thumbnails Transmission on a turbine, anyone ever try it?-img_9779.png   Transmission on a turbine, anyone ever try it?-img_9780.png
BigSilverCat is offline
Old 12-30-2017 | 10:35 AM
Tyson didn’t my old turbine boat have a pair of your trans in it at one point?
302Sport is offline
Old 12-30-2017 | 11:15 AM
yes, they never ended up paying for them so I had to repo them.
Old 12-31-2017 | 07:24 PM
Coolerman's Avatar
PF Marine
We use the 72lhp with our motors, so they should have no problem handling a turbine.
Coolerman is offline
Old 12-31-2017 | 07:26 PM
And a late entry for post of the year!!!
endeavor1 is offline
Old 01-01-2018 | 07:57 AM
If Turbine Marine aren't using them there has to be a good reason, they have built more turbine boats than anyone else out there.
Possibly because if you are in neutral or shifting between without the brake applied your N2 will be close to 100% without any load or resistance even with he N1 at idle.
999JAY is offline
