Replacing trailer bunks
Old 05-23-2018 | 01:10 PM
Gary864's Avatar
Originally Posted by Sydwayz
Many years ago, I custom ordered some 4"x10" long bunks for a bunk trailer. It wasn't a big deal, and was not terribly expensive. I think I ordered Cypress which would be the best wood to use. I don't recommend treated lumber, and neither does Myco. Just plain Pine UNLESS you go to Cypress.
The worst think I found about the bunks "wearing" on the typical bolt-together aluminum trailer is that their were only a couple of through bolts supporting ALL the weight of the boat. This is because my bunks were not touching the trailer frame, but were suspended by those bolts above it.
Either have those big bunks setting all the way down on the trailer frame cross members, OR install some small blocks of wood to make up for the suspension that the through bolts are supporting. This was on a POS Rocket trailer under my 26' Sonic. I was much better when I was done with it.
that is exactly what I heard in the past. I been loading and unloading for years with out them so I won’t use them at this point. I only now have 1 in and 1 our with the trailer
Gary864 is offline
Old 05-23-2018 | 02:16 PM
convincor's Avatar
Originally Posted by Boatally Insane
I did.. .
Only downfall is they are REAL slippery
..When pulling the boat out I now have to leave the boat idling in gear until the winch get hooked
or it slides back in the water as you're walking up the bow....
And hook up the safety chain before pulling up to far. Have seen winch straps snap.
convincor is offline
Old 05-24-2018 | 09:55 AM
As someone previously posted treated lumber has a corrosive effect on the hardware used to fasten the bunks to the trailer.
Interceptor is offline
Old 05-24-2018 | 10:17 AM
Indy's Avatar
Member #154
Not true, stainless or hot dipped galvanized will be fine.
Indy is offline
Old 05-24-2018 | 05:55 PM
What then caused the galvanized lag bolts to erode ? I backed down a ramp, the boat floated free and so did two of the four bunks. The fasteners were eroded to a pointed shape with no thread left to grip the wood. This is on a fresh water use only trailer.
Old 05-24-2018 | 06:11 PM
Indy's Avatar
Member #154
Most decks in America would fall off the house if that was the case. Finding fasteners that are compliant with treated lumber is not hard, we use numerous types when we build decks. There has to be some sort of electrode potential between aluminum (is your trailer aluminum?)/steel/galvanized products...it's not the treated lumber.
Indy is offline
Old 05-24-2018 | 06:17 PM
If you do a little Googling you will see that its not uncommon for pressure treated wood bearing the mineral copper to be very hard on galvanized fasteners.
Thunderous is offline
Old 05-24-2018 | 06:37 PM
Indy's Avatar
Member #154
Hot dipped?
Indy is offline
Old 05-24-2018 | 06:53 PM
Buy cypress bunks.Dont brother with any other wood. No other wood can compare. Then carpet them with something suitable.
veloc410 is offline
Old 05-24-2018 | 06:55 PM
Originally Posted by Baja Rooster
Lol I never considered that.
my boat slips with just carpet. Plastic sounds dangerous????
veloc410 is offline
