Boat Pulls Hard Left Under Acceleration >
Old 05-28-2018 | 09:58 PM
Default Boat Pulls Hard Left Under Acceleration
I am looking to buy a 94 Formula 252 SS 7.4L Bravo III 370hrs , Under straightline acceleration it pulls pretty hard to the left, Is this normal ??? I have not seen this this before with other Boats
drtracer58 is offline
Old 05-28-2018 | 10:29 PM
jeff32's Avatar
Perhaps a worn out gimball ring pin? It usually does it when cutting off throttle slowing down but i guess it may have a similar smaller effect accelerating! Or a loose in steering system somewhere?
jeff32 is offline
Old 05-29-2018 | 05:44 AM
I didn't notice it when slowing, But I had so many things I was trying to absorb that I probably didn't pay attention to that, It steered fine until maybe 25-30 m.p.h. when I started to accelerate, Is it possible that it spun a prop hub ?? Boat has been sitting for a few years with no activity ?
Old 05-29-2018 | 06:07 AM
Could it just be normal prop torque?
thirdchildhood is offline
Old 05-29-2018 | 07:10 AM
Wobble's Avatar
SORE MEMBER
does it have both counter rotating props? matched set?
Wobble is offline
Old 05-29-2018 | 07:40 AM
madbouyz's Avatar
Something's not right . First off , there's no prop torque with a DP unit and there's no prop bushings on a B3 either .
If you let go of the wheel at any given speed it dramatically pulls to one side on its own ?
madbouyz is offline
Old 05-29-2018 | 06:37 PM
No issues up to 20-25 M.P.H. Then when I wanted to go up to maybe 40 or so , It was pulling hard to the left
Old 05-29-2018 | 06:56 PM
BUP
steering actuator
power steering pump
BUP is offline
Old 05-29-2018 | 10:25 PM
Were both engines at the same RPM's as you were trying to accelerate? If not it will pull to the lower RPM side.
Tractionless is offline
Old 05-30-2018 | 06:43 AM
Wobble's Avatar
SORE MEMBER
24' most likely a single
Wobble is offline
