Sixteen Power V-16 Engine Program Update: 10 Blocks Completed >
Old 06-19-2018 | 02:11 PM
Originally Posted by Baja Rooster
True. I’m gonna guess that would be the lower end with mild cams and NA. It should clean up the engine bay and not look like a tractor pull.
Originally Posted by JIMKID Motorsports
acually we are the same weight as a blower motor and 4 inches narrower than abig block
the pics can be deceiving, to me they look like monster big. It would be interesting to see them in different setups like blowers and so on..
29Fever is offline
Old 06-19-2018 | 06:17 PM
JIMKID Motorsports's Avatar
definetly long endurance and big power if they want
JIMKID Motorsports is offline
Old 06-21-2018 | 12:21 PM
On Time's Avatar
Originally Posted by Level III Chaos
Someone say V16?
https://www.motor1.com/news/83357/fo...cket-roadster/
Looks like Herman's old car...
On Time is offline
Old 06-21-2018 | 01:19 PM
Originally Posted by 29Fever
I think a 16 cylinder motor is cool, but the power to weight ratio seems a bit off at 1100hp. A 540ci blower motor can make 1100hp easy with less weight, unless your going for the cool factor of having 32 cylinders.
Key item with the V16s is hp/cyl. They should idle smooth and be super reliable at the 1000hp range. Looking forward to seeing these in a boat!
VortechSS is offline
Old 07-01-2018 | 08:41 AM
you get it finnally some body figured us out cool
