trim sender and limit replacement >
Old 06-25-2018 | 08:31 PM
Default trim sender and limit replacement
I just watched your video on replacing the trim sender and limit switch. Where can I buy the kit that was used in the video
maasgroup is offline
Old 06-25-2018 | 08:45 PM
Have you tried the internet...they sell all sorts of things there....
phragle is offline
Old 06-25-2018 | 08:57 PM
SB
SB is offline
Old 06-25-2018 | 09:19 PM
BUP
I have them prob 5 sets on hand all the time.
do not cut the wires and splice to install. I know its alot easier to do so but that way of installing - the limit and the sender will not last.
BUP is offline
Old 06-25-2018 | 09:25 PM
then there was the kit with longer wires so you could just drill a new hole in the transom to run the wires, I kid you not......
phragle is offline
Old 06-25-2018 | 09:30 PM
SB
SB is offline
Old 06-25-2018 | 09:52 PM
Dont be that guy.....
phragle is offline
Old 06-26-2018 | 05:28 AM
Yes there are many kits out there , i like the one in the video cause of the boot that stops it at the right location in the housing. Not sure if the bulkhead connector came with it or if that has to bought somewhere else. That's why I'm asking about where that particular kit was bought
Old 06-26-2018 | 06:07 AM
Don't be that guy. For an afternoon and under $100 bucks you can do it the right way.Be smart and do the bellows while your in there..its probably time anyways...
phragle is offline
Old 06-26-2018 | 12:27 PM
BUP
its a life saver until the rubber gromments that pass thru the transom assembly from the OEM installed ones degrade overtime cause a water leak.
BUP is offline
