alternator pulley
Old 07-06-2018 | 01:45 PM
Default alternator pulley
Looking for an alternator pulley, smoked mine. Its a 6 rib aluminum pulley that is the Merc blue. I found the Merc part number but was hoping that there was another option. I could care less if its blue
BTW its a 500EFI
kevinb230 is offline
Old 07-06-2018 | 02:40 PM
Take it down to your local alternator rebuilding shop. Good chance that they will have something
snapmorgan is offline
Old 07-06-2018 | 03:43 PM
Unfortunately I tried that, they said I should try Merc, they knew what it came off of but haven't been able to match it with mine or their previous experiences
Old 07-06-2018 | 05:07 PM
Been unable to find the blue one, whipple does have a 10 rib for $170. The black ones are part number 807757T and could possibly be repainted
AllDodge is offline
Old 07-06-2018 | 05:19 PM
Woops messed up again ..... U did say alternator pulley not idler pulley, sorry, will keep looking
AllDodge is offline
Old 07-06-2018 | 05:23 PM
Found part number 842421T
BAM at 118.16
Walmart 105.81
Boat.net 109.22
Hardin 117.95
AllDodge is offline
Old 07-06-2018 | 07:13 PM
1 MAIDEN AMERICA's Avatar
Same thing happened to mine on a trip. Packed it full of shim stock wound like a clock spring, and JB Weld. Finished the trip, another 150+ miles. Replaced it with one from BAM when I got home. Of all the things to fail on a performance boat, that was weak!
1 MAIDEN AMERICA is offline
Old 07-06-2018 | 10:51 PM
This makes me want to check all of the pulleys yearly, aluminum on steal heat at different rates and thus causes the issue. I had a slight squeal last trip, though it was the belt. I figured I would address it when I got home. Little did I know
Btw for all those reading, when an aluminum pulley spins on a steel shaft they are both trashed
Old 07-07-2018 | 09:41 AM
Nice Pair's Avatar
BTW its a 500EFI
Might want to call around a little, steel would probably holdup better.
https://www.summitracing.com/parts/tff-7610b?seid=srese1&cm_mmc=pla-google-_-shopping-_-srese1-_-tuff-stuff-performance&gclid=Cj0KCQjwyYHaBRDvARIsAHkAXcv5hlej L2bKEgnnXIciRGsDYfJmbEnXTlDXhneuZZe-ZyBwBJhpRSwaAjFtEALw_wcB
Nice Pair is offline
