-   -   Gil manifold to riser studs stuck!! Any "tricks"? (https://www.offshoreonly.com/forums/general-boating-discussion/357060-gil-manifold-riser-studs-stuck-any-tricks.html)
BUP 10-08-2018 03:48 PM
paint stripper gun high heat and candle wax dripping down into the threads.
other helpers
freeze off by CRC
the 50 / 50 mix of tranny fluid and acetone
Interceptor 10-08-2018 03:57 PM
When you get real desperate cut a notch for a screwdriver in the broket stud and try a Impact Driver. They work well on studs stuck in aluminum motorcycle engines.
